It is currently Fri Jun 27, 2025 10:47 pm
PostPosted: Thu May 11, 2006 4:08 am
I'm building my first guitar and about to glue on the fingerboard. I've been trying to check how it aligns with the rest of the guitar before I glue it on. I found that if I extend a straight edge down the center of my fingerboard when aligned on the neck, it does not intersect the center of the end graft. it measures to be off to the side by 2 or 3 mm.
What are typical tolerences?
PostPosted: Thu May 11, 2006 4:11 am
Is it the fingerboard, or the neck that's off? Is the end graft centred? Because fixing side to side alignment of 2-3 mm should be pretty simple; take off a tiny amount off one of the cheeks, assuming a bolt on.
PostPosted: Thu May 11, 2006 4:24 am
It's a classical with a spanish style neck-heel. I think the error is spread among the end graft placement and the neck alignment. Sounds like a mess but it doesn't look bad until I put a straight edge on it. My $100 yamaha that I play is worse but that doesn't add much comfort. I checked a $1000 Martin and it was perfect within my measurements.
PostPosted: Thu May 11, 2006 5:45 am
Oh, OK. Anyway, 2-3mm is very, very little. I'd be fine with that, especially on a spanish heel instrument (I do my necks so I can futz with 'em).
PostPosted: Thu May 11, 2006 5:55 am
I wouldn't worry about it lining up with the end graft - the question is how does the bridge look when it is aligned corrrectly with the fingerborad. As long as the bridge isn't way off center when it is lined up corrrectly with the centerline of the fingerboard and parallel to the frets, then no one will notice.
                           Paul
PostPosted: Thu May 11, 2006 6:11 am
Ouch, didn't think about the bridge, I almost hate to take a look. Oh well, I guess I'll make a dummy bridge tonight and check it out.
PostPosted: Thu May 11, 2006 6:12 am
Okay, so 2-3 mm is tolerable, thanks.
PostPosted: Thu May 11, 2006 7:21 am
No one will ever notice unless you tell them.
PostPosted: Thu May 11, 2006 7:33 am
Or one of us tell them
PostPosted: Thu May 11, 2006 8:45 am
Shouldn't the bridge be the last thing to be glued, so it can be aligned with the neck?
PostPosted: Thu May 11, 2006 10:44 am
Marc, if it's any consolation my endgraft was "off center" too - easily by as much as yours. I cut mine with an exacto knife and a chisel, and I added the endgraft to make up for a 1/2 inch gap that I had between the two sides. Nobody will notice. The issue is making sure the bridge is properly aligned with the fretboard.
PostPosted: Thu May 11, 2006 1:25 pm
[QUOTE=Mattia Valente] Oh, OK. Anyway, 2-3mm is very, very little. I'd
so I can futz with 'em).[/QUOTE]
I agree with Mattia....not worth worrying too much about. 2-3mm isnt
going to be obvious. Larger errors can be a problem as they become
obvious where the split 19th fret intersects the soundhole.
The classical Im currently working on has centreline out by 4mm. I just
compensated by repositioning bridge slightly off centre seam....only a
luthier would pick it up. If youre a gun at gluing up tops with no visible
centre seam then probably the average luthier wouldnt pick it up either.
Cheers Martinkiwigeo38848.9370486111
PostPosted: Thu May 11, 2006 1:42 pm
First name: R
Last Name: Coates
City: Selma
I picked this laser up at home depot for six bucks. It's helped me quite a bit.
PostPosted: Thu May 11, 2006 2:44 pm
First name: Rich
Last Name: Barbera
City: Bay Area
[QUOTE=RCoates] I picked this laser up at home depot for six bucks. It's helped me quite a bit.[/QUOTE]
I like that...Star Wars Revisited!
~ Lasers in Lutherie ~
PostPosted: Thu May 11, 2006 10:39 pm
[QUOTE=RichB] [QUOTE=RCoates] I picked this laser up at home depot
~ Lasers in Lutherie ~    [/QUOTE]
What Ronn neglected to mention was the effort that went into to gluing
the top back together after he'd lasered it in half!
PostPosted: Thu May 11, 2006 11:08 pm
Checked out how the bridge will look. Seems there is enough asymmetry in the lower bout that it came out very close to centered between the edges even though the center of the bridge will be a couple of mm off the joint line of the top. I think two wrongs made it look right, just luck.
PostPosted: Thu May 11, 2006 11:11 pm
Good idea. I have one of those for hanging shelves, I'll give it a try to see exactly how far off I am.
PostPosted: Fri May 12, 2006 5:46 am
FWIW a picture of the mistake.
PostPosted: Fri May 12, 2006 6:14 am
Mark, locate the bridge with things like they are based on the neck and double stick tape it down. put the guitar away for a day or two then come back to and tell me if it is noticible! Don't put a laser on it, just set it up on a stand and take a good look. You will likely not notice it in the least, because the bridge is many inches away from the graft. You or anyone else's Eye will not see the off center. The important thing is the relationship between the neck and the bridge. The end graft is just dressing on the turkey.
PostPosted: Fri May 12, 2006 6:57 am
Marc, your fingerboard alignment is perfect compared to mine, check on this picture for the big E string on my first build, the neck is so off centered that i call my guitar 10 to 6!
PostPosted: Fri May 12, 2006 7:11 am
Wat Woow MichaelP38849.6750578704
PostPosted: Fri May 12, 2006 7:28 am
Serge, Thanks! I don't know what to say except that picture makes me feel okay about my first guitar.
PostPosted: Fri May 12, 2006 7:37 am
That was the goal! Mission accomplished!
cron
